Kerfing on Arched-Back Guitars
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=51973
Author:  KawaiianPunch [ Sun May 26, 2019 9:20 am ]
Post subject:  Kerfing on Arched-Back Guitars
Are kerfing angled on arch-back guitars?
Author:  Barry Daniels [ Sun May 26, 2019 9:50 am ]
Post subject:  Re: Kerfing on Arched-Back Guitars
Yes. This is most easily achieved with a radius dish lined with sandpaper.
Author:  Colin North [ Sun May 26, 2019 11:49 am ]
Are they? Sometimes at least not I believe.
From this webpage - http://chandlerbryan.com/BuildArchtop1.html
Quote:
In one way at least, archtop construction is a little simpler than flattop: the edges of the top and back where they join the
sides must be completely flat. That is to say, the edges of the sides (rims) are parallel.
Author:  Barry Daniels [ Sun May 26, 2019 12:07 pm ]
Colin, I thought he was talking about a normal acoustic guitar with a radiused back. Yes, an arch-TOP guitar is usually built with a flat connection between the rims and the plates (at least the ones I have built). Perhaps the OP can tell us which guitar he is asking about.
Author:  Colin North [ Sun May 26, 2019 12:21 pm ]
That would be a good idea.
Author:  KawaiianPunch [ Sun May 26, 2019 2:33 pm ]
Are y'all suggesting most arched-back guitars/ukuleles are flat enough on the outer edge to not need angled kerfing?
Author:  Barry Daniels [ Sun May 26, 2019 3:03 pm ]
Depends on how you build it. If you make the back with a full radius then you need angled kerfing. But, if you make a back by carving from a thick piece of wood (like a traditional arch top guitar), or you form a back like in your photo, which shows a complex curve and re-curve resulting in a flat area along the perimeter, then you would leave the kerfing flat.
Author:  KawaiianPunch [ Sun May 26, 2019 3:34 pm ]
So, regardless of the style, the kerfing needs to be flush/glued with the back-board.
Author:  Barry Daniels [ Sun May 26, 2019 6:37 pm ]
Of course. You normally want joints to close up with little pressure before you glue them. Unless you have a specific reason to make a "spring joint" where you want some added tension.
